Someone sent me a package some time ago /ubbthreads/images/graemlins/wink.gif and I was a bit lazy to actually start using the things inside it but finally decided to do something. I am going to buy some conductive epoxy soon, and I would like to know how to use a Micropuck. I understand that these are a bit old, but if it works, thats just fine. It has a little white sticker saying
Micropuck 2000
2 cell -> 350ma
Then there are 2 wires sticking out on 2 parallel sides. one pair is red and black, the other is green and orange.
Edit: I changed the title a bit because I had another question. Does the Micropuck get damaged if I file it down a little? I wanted to fit 2 into a minimag, and I need to file it down a bit in order to do that. If I was to file down the corners a bit, would the pucks still work?
One more Edit: I am trying to make a converter board out of one micropuck. I just made a custom emitter board out of oaktag /ubbthreads/images/graemlins/blush.gif not that I cant afford the stuff, but I cant buy anything online but Im sure it will do. I know that the positive input wire should go at the base of the entire thing and act as the positive contact button. I dont know exactly where to place the negative input wire. Should I make sure it touches the bare inside of the host so it makes contact with the kroll?? I am using a MiniM@g.
Micropuck 2000
2 cell -> 350ma
