I had a bad die set of 35 Led Christmas lights they made me chop off the first light and the plug which is a 3amp 125v fused plug. Where would I find this and should I put a resistor in place of the missing Led to reuse the setup? It's just a 2 prong plug with a slide out part with 2 tiny fuses equalling 3 amps. I'm thinking maybe to in line fuses can anyone help solve this problem. All the autoparts stores are rated 250 vac and thats too high of an amp in line anyway. The lower in line mini fuses are 32 v max . PLease help
