[ QUOTE ]
savumaki said:
HELP--I am now on information overload.
Problem; we are looking for a light which has reasonable flood qualities with a generous amount of output for hunting and camping. Our best choice to date is the Nuwai ALX 352L which appears to have the light quality AND is in our price range-$100.00 max.
Thanks----Karl /ubbthreads/images/graemlins/confused.gif
[/ QUOTE ]
Karl: While not very experienced, I do have some opinions:
First of all, do you backpack into your camping/hunting area? That will reguire a totally different outlook than if you hunt from a base camp, where you travel to by vehicle.
First: On your person: Bright, lightweight, and long run time. You may wish to hike to your tree stand before daylight, but that should require about a half hour or less. Even if you don't cary a backpack, lighter is better. I usually carry a canteen, plastic poncho, snacks, 10 rounds of ammo, binoculars, toilet paper, plus rifle, with scope and ammo. You don't need extra weight.
Hunting in most of the U.S. is legal only till 1/2 hour after sunset. If you are confused by then, a light with some run time is good. It will help you set up emergency camp, find camp safely, or maybe keep you from falling off a cliff while thrashing around in the dark (Don't ask how I know this!) UK eLED 4AA, Mini Mag, stock or with MJLED or Opalec will do well here. For $100, you can buy several. A headlight is also a good choice.
If you want to carry it, the 2 or 3 D or C maglight will provide throw, but with a weight penalty. The Streamlight Twin Task 3C light is lighter, and has several light levels. I like mine. A back up is a good thing, in case the unthinkable happens, and you don't have a spare bulb, or a wild animal runs off with your light. Extra batteries make sense, too.
A good fluorescent or LED lantern provides more "friendly" light for the campsite, if it is a base camp. If you are backpacking, a good headlight makes a lot of sense. Again; long run time, back-up light, and extra batteries.
Good luck, and good hunting! /ubbthreads/images/graemlins/cool.gif
