Well, I got all the stuff for my Mag85BP together but hit a snag. I noticed that one of the little tabs on one of my EL 3-to-D v2's was partly busted off so I had trouble getting it to stay on the adapter. I took it off and looked closely and decided I could press down and twist and if I was careful, it would stay on. It did.
Unfortunately, I think I didn't put it on in quite the correct orientation. It looks like the way this adapter is designed, you can short out two of the cells if you don't put it on just the right way. Sure enough, I smelled melting plastic and felt the adapter getting hot. I quickly opened it up and dumped the cells out, so the cells were undamaged, but the contact strip in the top part fell off--it was only crimped onto a little plastic button that partly melted.
I guess I'll try putting the contact strip back on with super glue, which I hope will hold til I can get another adapter (Wayne doesn't list them any more but Waion has some similar ones, I think).
Ultimately though, I think the 3-to-D adapter design could use improvement. I may bite the bullet and order one of fivemega's 9aa-to-3d adapters, if he has any left.
