luxlover
Banned
I need help from those CPF members who are well versed in the matchup of CR123 and R123 battery chemistries, with Luxeon III emitters.
I am about to have a stock Nuwai QIII modded with either a TY0H or a TW0J emitter. I would like to use a 700mAH R123 battery with this light, if at all possible. Being that an R123 right off the charger measures 4.2V and the same battery has a 3.7V during most of it's discharge cycle, would it be safe to use this battery with either of the abovementioned emitters? Since both emitters would be overdriven by this battery, placing the light in direct drive for a period of time until the battery voltage drops significantly, would the TW0J (J Vf = 3.27-3.51V) run cooler than the TY0H (H Vf = 3.03-3.27V)?
Should I forget about using an R123 with either emitter altogether, and just settle for the basic CR123? If it is advisable to use only CR123s, then which emitter should I request if I want higher efficiency, lower heat generation, and a longer runtime? I have lights using both emitters, and I would be happy with the tint of either of them. Thank you all.
