I just applied for an intership with target to get some experience in leadership. When I shop in stores like target or walmart I pull out my legend xl light and use it in areas where I am looking for a product. The only downside in that case is the beam is too much of a spot and a more flood like light would work. I have not tried my xpg, I know it has somewhat of a flood beam, then of course if you remove the lens, its a wide angle light for sure.
Is there a wide angle pocket light with the hot spot of the legend xl or p61 lamp? I had considered buying one of those pistol grip style hand held spot lights like what cabelas sells, but Ive often thought several million candle power would be too much at such a short range unless I wanted to set the merchandise on fire.
I am sure it would be fairly quickly before I remember what merchandise is where and this may not be something i will always need, but just to start off with.
I have also considered that mag 6 cell 6 5 watt led upgrade. Its a round disk with 6 5 watt leds in it and it is said to throw out a wide angle beam with no regards to battery life. That may be in the neighborhood of what i want, but handling a 6 d cell mag light or 6 c cell maybe too long and heavy to use off and on throughout the day. Can that be powered by a smaller flashlight?
Just wondering.....
Just wondering.....
