Okay heres where I'm at:
I'm currently in the process of building a laser projector. I have my scanners working, and the beam table I engineered, but the problem is with getting the CDRH required shutter to work. I'm using a 12vdc 900mA power supply, a 12vdc ledex solenoid, a 12vdc 2amp relay with a 5vdc 42Ohm coil.
When I apply 3vdc @ 100mA to the relay coil, it snaps and the shutter works, although when I connect it to the TTL line of my DAC card, the relay does not work.
I have also tried a 30vdc 2amp relay with a 4.5vdc 145Ohm coil, with the same result.
Any ideas?.. Thanks for the help..
