wmpwi
Well, this was another expensive lesson. I was trying to remove some excess solder on my new blue Cree Xlamp chip. I was holding it, rather gently I might add, in a pair of forceps when I heard a "click" sound. Upon close examination, I found that I separated the top led cover from the base exposing everything. Interesting, but painful. The following picture is of poor quality, but should give you the idea. The top half including the lens is a hard convex shell, but it's actually filled with a soft silicone gel type material (that would be the interesting part). Also interesting is that the chip still works, but doesn't seem as bright without the lens. The learning curve on the whole flashlight mod thing is getting a tad expensive. I may have to leave the mod part to the pros.
