Re: What\'s this ambient/diffused LED light \"thing\"
i would like to see what the OP was refering to in the context that it was used ??
but to continue the discussion, i will add some observations.
ya average HIGH-POWER Dome led, has about a 60*-120* as high as 180* output,
with a reflector on a normal dome light, only the stuff traveling to the reflector (about 20* and over) gets turned into whatever spotting, the reflector can accomplish. the rest of the light, the light that did NOT hit the reflector, spills out into a lower level round, of about 20*.
you often cannot SEE that in the beam pictures, there is a SPOT and a low level flood, when using a reflector on a DOMED led.
Reflectors with high-dome leds, seem to be the most efficient in what heads FOREWARD out of the light (lumens). they make a good spot, and can have a great flood around them. (best of both worlds, for walking light)
its easy to think of, when you realize the parts, you have a bulb that is 120* , and a reflective cone around it, there is a ammount of the light, that doesnt have to hit that reflective cone to get out.
With Side emitters, almost everything that hits the reflector, goes to the spot that the reflector is aligned for, there is very little Other light, that heads out the front that does not hit the reflector, because the top of the led is DESIGNED for 360* output.
so there is far less of the perefreal lighting , and mostly just a spot.
side emitters are not so efficient, yet there is far less perefreal light, and its mostly all just spot.
and because the side emitters output is a TIGHT 360 point, it makes a tight beam, depending on the reflector (of course).
With OPTICS, ALL of the light heads through the optics, even in a dome, so that is LOADS different, with optics most of the light becomes the spot, and there is Little of this "spill"
BUT
with most optics they are not very spotty, they are VERY well blended , and dont have nasty flashlight rings and donuts and blackholes.
They have optics in all kinds of angles and styles, from floods, lines , and spots as high as 6* , but some of the ratings for the degrees, is based on "from center" meaning a 20* could be 20x2 going each way from the center.
the 6* one is not much spottier than the 10* lux standard thing, i think there is limitations to this type of refraction, and still having smoothness.
optics have a reduce efficiency, and some of the light spills out the sides , and is lost in the light (doesnt go foreward) this can be reduced by reflectivity behind the optics, and should have been fixed by silvercoating the back of the optics.
sooo, basically unless you have the high-loss side emitter, you dont get a SPOT ONLY tight spot, that ONLY lands in ONE area. and untill it only lands in one area, your IRIS of your eye will be effected by the ambient or perefreal light.
and finally, there is a reflector with a 2* spot, it looks a lot like the thing on a surgeons head its a Spot reflector, its 2 inches and VERY flat. it will make a spot so tight that it blows away the spots in about anything.
i have yet to see it be applied in many thing, yet it would fit in a single lux mag.
there is 2 sizes of it, and its available on a non-english (US) site.
it makes a harsh but kinda nasty spot, of a side emmiter, or a dome.
then there is the super rediculously long reflectors that have harsh spots also, and very little light just spills out from the dome.
hope any of that helps, that is the way i see it, some of it you cant see in the pics, except for the pics where the person specifically showed it, by adjusting the camera.
anything else is just the fact that with 3W of luxeon, your not going to compete with 9-40watts of incadescent, but you might have a battery that still lights something after 2 hours
IMO you should have 1/2 the power of leds to gain the same output as high-efficiency ("zenon" or halogen) overdriven short lived bulbs, to have similar output. they are efficient, but not so efficient as to think that an underdriven 1W is going to compete with a 24W battery vaccume /ubbthreads/images/graemlins/smile.gif
