andrewwynn
I recently acquired some detailed information about Lumiled's upcoming K2 emitter.. so of course i had to make a computer model to see how it will fit in my projects.. it's kinda cute so i wanted to share.. and maybe start a thread to discuss the implications with the new emitter coming.
The specs show that there are two levels coming.. i call them 'high power' versions and 'low power' versions.. the 'high power' models are designed to run at up to 1500mA and the 'low power' models are designed to run at up to 700mA.. actually it's a little bit confusing because it looks from the specs you could run them all at the higher drive levels.. maybe somebody more in-the-know could help explain that..
In any event.. they are going to have 5 brightness bins.. R, S, T, U, and V.. they are similar to the lux 3 in the grouping regarding their output, but the bin rating i think is at the 'base' drive level (which is 350mA for the low-power model and 1000mA for the high-power model.. so this means that the 'S' bin which is rated at 350 actually outputs the light of a Ubin Lux3 when driven at 700mA.
the R and S bin models are in the 'low power' group and rated from 75 to 100 lumens max
the T, U, V models are in the 'high power' group and rated from 120 to 140 lumens max
(at 350mA.. the R and S are 45 and 60.. at 1000.. the TUV are 80, 100, 120).
the estimated power to drive the emitters:
The low-power models range from 1.2W on the low side and 2.5W on the high side..
The high-power models range from 3.7W on the low side and 5.8W on the high side.
Looks like they managed to get the average Vf down, and i'm hopeful that the typical K2 will have a Vf similar to the J-bin Lux3 now.. only time will tell where the bins end up.. and how the color binning situation will work out.
Some very exciting things i think are coming.. with the advent of making them SMD technology and being able to machine-place and solder... i think that the price will be held down from tremendous production quantities possible.
Notice that the emitter leads are much smaller.. and they leave all 4 on.. (the lux 3 is fabricated with 4 leads and two are cut off).. they are going to make K2 emitters with matching leads so they match the footprint of the lux3.. for replacement and possibly easier hand-soldering.
Notice the slug is hexagonal.. i have no idea why, but guessing it makes it easier to machine orient when building, or helps fit into the square body.
Notice the alignment holes kiddy-corner.... for uber-precise placement.. put a hole in your PCB and put a pin through the hole and get within .05mm centering of your lux!
Notice the one corner not chamfered.. that side is the cathode... technically they say that the chamfered corner is the anode.. but there are 3 chamfered ones so it's backwards from how i'd have done it.
Some size restrictions will come into play with some lights or reflectors that are 'used to' the lux 3 being 8mm diameter..
slug size: 5 1/4 mm on the flats.. approx 6 mm to the points.
the chamfered corners fit in a diameter of 8.76 mm
the long corner fits within a 10.35 mm diameter
the emitter leads fit within a 12.15 mm diameter.
The main issue that is affecting my designs is that corner point.. it may not fit in the IMS27 or similar reflector that has a 9mm opening.. it would have to be shaved down to fit, which surely would not be a difficult thing to do.. in a mass-production job like MM.. i would not want to be cutting down each emitter... so i'll be re-designing the reflector to fit outside that 10.35mm diameter... tough call on the IMS 27.. if it's easier to cut the reflector or the emitter, but the emitter would be my bet... fortunately the IMS 17 and 20 only come to the base of the dome, so are unaffected by this issue.
I have no idea when to expect these emitters to hit the market, but the MM is designed to use and take advantage of several advantages of the upcoming K2 emitter, so i hope they are out by the time MM is ready to go to production.. I will make the prototypes with Lux3s so i don't have to wait.
on the low-power side of the equation.. the S bin model is rated at 60 lumens at 350mA.. that is mind-blowing.. means that if somehow i could get that emitter into a nano it could be double the output.. could be a little tricky given that the insides of a peak head are 8mm diameter..
Well that's what i know.. i can see some pretty amazing mods coming from this new emitter.
-awr
