KevinL
b2eze\'s Mag Light Engine
Finally, a nearly-TK drop in for Maglites!
Actually it is not quite a drop in, rather a screw-in /ubbthreads/images/graemlins/nana.gif
b2eze was kind enough to send me one of his new LEs for the Mag, incorporating both his awesome PR base and a new front end threaded to fit a D-cell head. Now my Mag85 can be BOTH incandescent and LED providing I remember to change the batteries before I put in the LED drop in. (10+ volts from fresh NiMH to a Lux3 = kaboom /ubbthreads/images/graemlins/eek.gif)
As always, excellent precision machining work here. Dirty fingerprints are MINE from fingers covered in thermal grease /ubbthreads/images/graemlins/tongue.gif
Building the LE is a snap - easy enough I'd recommend it to any newbie, even those who are just beginning to become comfortable with a soldering iron. I did the OA4D Cookbook (in sig) as my second mod and MAN do I wish I had this LE back then!!
I'll provide a brief tutorial, although I am sure it is self-evident.
Ingredients:
1. Light engine from b2eze
2. Luxeon 1 or Luxeon 3 star
3. Resistor (only required for 4 D cell Mag)
4. Reflector/optic - my personal recommendation is the SO20XA or SO27XA reflector
5. 3D or 4D Maglite
6. Optional: UCL or glass lens
Lay on a thin coat of your chosen thermal compound. You need not use an adhesive version, because the three screws provide a very solid mechanical interface. Place star, align properly, and screw it down.
Strip wire, tin and solder to one of the positive pads of the star. If you are using a resistor, solder one end to the wire and one end to the star. You may trim the wire to suit, I did not trim it (in case I want to re-use the LE)
Check if the ground screws are making contact with the negative pads. If they are not, what I do is build up a solder blob on one of the negative pads until they make contact with the screw. Align the star so that the big screw covers one of the negative pads. The big screw is your ground screw.
Open up the Mag head and screw the LE in. Place the reflector or optic on top of the LE, and reinstall the bezel. Adjust how far your LE is screwed in to hold the reflector/optic against the lens without exerting too much pressure.
Screw the head back onto your Mag, light up and go! Yes there is actually a slab of glass in front of the reflector and everything has been completely installed in the last pic, just that it's glass so clear that it doesn't look like there's anything in the camera. /ubbthreads/images/graemlins/thumbsup.gif
Another free plug for www.flashlightlens.com where you can get your choice of glass for various kinds of light.
Ingredients:
5. 3D or 4D Maglite
