<font color="red">Closed.</font>
LionCub 168A 1st (and only) run bodies are hereby offered.
The LionCub 168A body is used with the Pila 168A lithium ion rechargeable battery instead of the stock R123 battery when extended capacity is more important than small size. It provides a roughly 3x increase in runtime (based on the 2000 mAh capacity of the 168A over the stock R123 battery's 700mAh), and fills the hand better.
Many people found the 168A body an extremely useful LionHeart upgrade. As a result, my second run was approximately 3x the first. As I only intend on doing one run of these for the LionCub, please order now!
The LionCub 168A will fit the LionHeart perfectly if you remove the o-ring, so if you are still looking for a LionHeart 168A body, this is your opportunity. However, the styling of the body will match the LionCub.
The 168A body will be offered in three finishes:
<ul type="square">[*]Brass[*]Aluminum (unanodized)[*]Natural HA III anodized aluminum[*]Black HA III anodized aluminum[/list]
Actual colors may vary.
They are 1.38" longer than the stock R123 body. Due to the diameter of the 168A battery, the knurled diameter will be .88" instead of the stock body's .81".
Please clearly specify the finish desired from the list above and number of each with your order, and make the subject of your order "LionCub 168A Body". Thanks.
Price: US$43 deposit in advance, shipped CONUS, includes PayPal fees. Foreign orders please add US $7.00 shipping and customs fees per order (not per body).
Payment Methods
PayPal: Please send payment to [email protected]. Other: Other forms of payment (money order and personal check) are fine, but must clear before I ship. Please email me at [email protected] with your order information including shipping address, and I will send you my mailing address.
Notice: I am estimating that these will be shipped at the end of July 2005. Springs will be included. Using this body with any battery other than the Pila 168A may result in explosion or fire; you do so at your own risk.
Thank you.
Payment Methods
Thank you.
