Hi !
Here's a little glimpse of the upcoming new Aleph head ... the Aleph-19-UV.
In this pic it is mounted on an Aleph CR2 flanged body with a bald 2-stage tailcap running on a CR2.
The head is powering a Cree 7090 UV LED with a NG333 converter and uses a new 19mm reflector ... the McR-19.
Here it is shown versus the Aleph2 and its 20mm reflector. Note that thenew 19mm is way deeper! /ubbthreads/images/graemlins/ooo.gif
The head uses the new /ubbthreads/images/graemlins/cool.gif bezel ring that the McLuxIII-PD also sports as well as a Sapphire window. It isn't knurled.
Apart from those little differences, it is just a new ALeph head using a LE, only that in this case the LE is special ... UV.
Beamshots at various exposures as well as black and white, each time vs. an Inova X5T-UV with full batteries:
Note that opposed to the Inova the beam is perfect. In addition to the usual UV-flood this reflector offers a nice hotspot with the power to make things glow ... burn ... in a bright glare whereas the Inova only manages to achiieve a dull glow. The coronas however don't differ much.
All this is very nice.
BUT ... one can screw in other LEs with different LEDs to try out the new reflector!
A few examples:
And ... tata ... the LuxV (you heard it coming, didn't you /ubbthreads/images/graemlins/evilgrin07.gif):
A nice and almost even round beautiful flood.
With a LuxIII (sorry, no pic) you'll get a very floody yet not fully artifact-free beam.
In the end ... this one seems to be a very nice and forgiving reflector, and coupled with the Cree UV LED like in this package it is a pretty impressing Blacklight with some throw.
Point is ... you get a very small, fully regulated, highly efficient and relatively powerful UV light with impressive runtimes, depending on battery combinations in the modular system you are using. Should be a very nice accessory for SF E-Series user ... as an optional replacement head! /ubbthreads/images/graemlins/smile.gif
Don /ubbthreads/images/graemlins/thumbsup.gif
On the downside ... it is longer than the Aleph2 head and looks a bit goofy on some bodies, but that is just me /ubbthreads/images/graemlins/grin.gif
Note that with the McE2S 2-stage switch the low is lower than what you'd expect ... I took a nice shot in the eye at 333mA because I anticipated the low-mode, didn't even see it, and received high ... /ubbthreads/images/graemlins/icon15.gif
bernie
EDIT: edited in Don's comments from below as they seem essential to me and correct my statements where encessary /ubbthreads/images/graemlins/icon15.gif
"It may help to keep in mind that the beam shots are showing you the reflected visible portion of the light as well as any fluorescent excitation of the target but don't actually show the UV portion of the beam or its relative intensity, necessarily.
In some comparative experimentation with the Cree 7090 UV with a Nichia 2W and Shark 6W, the Cree really puts out!!!
According to the data sheets, the Cree puts out 200 mW of radiant flux as does the Shark and the Nichia sample I have is at about 90mW. The Cree, at just over a watt is the clear winner in terms of efficacy! This I should add is also at about 1/10 the price! "
A few examples:
bernie
