have bare luxes all over the place, for "area" type of lighting. only problem is Looking in them.
my headlight uses a semi bare, because i wanted full vision, instead of a spot.
Desklamps both use "bare" luxeons
the Car uses bares with plastic caps on them that i sanded to make square soft bulbs from the lux.
the kitchen uses bares, but it behind clear pyramid type diffusion.
i agree with the shadows stuff, that and if you LOOK into them, or they are in where you will look at the emitter.
put a bare in some kind of ring tube that HAD a reflector, and it makes (about) a 60* out of 120*s.
a bare does still have its "dome" and high domes are more spotty than the low dome things.
best way to tell what your degrees will be in any tube, would be to , assume there is a emitter down there, then lean it till you cant see the emitter. basically most of the light will go where you can see the emitter.
anywhere you could not view the emitter, very little of the light will be headed there.
put reflection AROUND the tube , and you will send out the rest of the light instead of wasting it, but the brunt of it will still be from the emitter out.
