Re: DB917 pulling 400ma from a R123, meaning it\'s
One of my favorite "practical" combos is a DB500 with a T??H emitter. With a Pila 168S, this light will run for 2.5 hours in regulation, and with an R123 I would guess you would get at least an hour.
You might ask, why not just use a Wiz2 if I want to use a rechargeable Li-Ion? Well the Downboy is very stable on low (through the McE2S resistor), while a Wiz2 is likely to flicker a bit, and I suspect the Downboy is also more efficient.
