I drilled a hole and widened out a spot for the head of the screw, holding the drill and moving it around like a CNC mill, and came close to killing the luxeon, and everything. I then found out that the hole was too big for the screw. I shoved some wire into the hole as I screwed down and it still was somewhat loose, but then took hold, I hope it stays. I don't think there is enough threads to hold it... I had to also grind the head of the screw down to a smaller size.
It's working now, but I half want to go back and re-do it, and the other half says to leave the sucker alone if it works.
I had a hard time getting the solder to stick to the screw head too, but it's shiny and I guess its making good enough contact. The aluminum solder job would work for 3 secs then go open circuit...
I thought the switch was a POS in this light, but it was just the emitter contact problem. The switch has no flicker at all and a very firm auidible click like a mag switch.
In any case, I'll take it back apart next chance I get and isolate the emitter leads and re-apply thermal pasted to the e-screw type thing.
The reflector works great in this light, you can look at it and see the top of the die reflected perfectly, and see some of the top bond wires projected in the beam. The beam is very tight for the size of the reflector.. Does a great job with this R/O... better than it did with the LD clone it had.
The switch does have about 1 ohm of resistance. From 3xAAA NiMH the R/O pulls 1.3amps, so with 1 ohm resistance what would it be getting?? Hard to measure tail cap current...
It sure is cool though, god I was about ready to smash this thing with a sledge hammer!!! /ubbthreads/images/graemlins/Christo_pull_hair.gif
I'll have to find someone with a digital camera, my dad will be gone for over a week trip, so I can't use his one at work for a while.....
