I recently got myself an Inova T2 as an every day carry flashlight. I bought it because of the relatively good battery life, decent output, and durability. However, I have recently noticed a problem with the light. If the light get jiggled around too much the batteries seem to get displaced so that the light does not function until they are corrected. For example, tonight I was sprinting at full speed in the dark, and I grabbed the T2 out of my pocket to turn it on to see where I was going, and it wouldn't turn on. I stopped to play with it for a minute to see what was the matter, and it just wouldn't come on unitl I took off the tailcap, took out the batteries, replaced them, and put the tailcap back on. I am now able to reproduce the problem simply by knocking the light against my knee while it is off. If the light is on, the batteries do not move, because of the pressure on the batteries. However, having a light that occasionally will not work is not acceptable. Is this a defect in this particular light, or is this a common problem in all T2s?
Thanks in advance for any input or suggestions.
