PhotonFanatic
<font color="red"> GROOVY! UPDATE </font>
<font color="blue">
Word just in from Dan that the Groovy!s are done!
Well, the bodies are done. Next to be done are the polishing, plating and assembly.
At this stage, here is what the serialized, engraved Groovy! will entail:
After we get the Groovy!s plated, I will open up a buy thread and start accepting PP payments. If you do not have a PP account, then a money order will work just fine. </font>
Introducing the CNC-123 Groovy!
Latest prototype, in polished aluminum:
What have CNC_Dan and I changed/added?
First, we have designed the light to be able to accept three different optics/reflectors without much modification at all. The new head will accept the Carclo, NX05 and Fraen optics if the mold stem is removed; just add the O-ring and it is done. The IMS 17mm reflector slides in place after the legs are trimmed off. However, the reflector is designed to be used with our double-sided anti-reflection coated lens, so that gets put on top of the reflector, you add the O-ring and you are done.
Speaking of O-rings, the Groovy! now comes with all seams/interfaces protected by O-rings, or in the case of the tailcap area, by the Kroll rubber boot. So the Groovy! will be watertight, but not designed for diving.
And speaking of seams, can you see the bezel/head seam? A very special thank you to andrewwynn for suggesting that modification.
Notice the body has been simplified, there is one combined battery/tailcap tube which holds both the CR123 battery and the Kroll switch.
And did I mention the grooves? Those in the head are great heat dissipators and feel great in your fingertips. The rear grooves are, believe it or not, replacements for the traditional knurling. When one wants to turn the light on by pressing on the Kroll switch, it can be a one-handed operation as the grooves stop your fingers from sliding forward. The rear grooves will cause a lot less wear and tear on your clothes, also, if you EDC it.
Should you want more grip, see the photo below with O-rings placed in the grooves.
As far as what you can use for drivers, just about any of the standard .55" diameter sandwiches will work as drop ins. There is a retaining ring to hold the sandwich in place so that when changing the battery.
Here is a retouched photo showing the seams eliminated:
Now use your imagination and consider adding some O-ring to the grooves at the back:
Price? $130, includes driver with TW0J Lux III and wrist lanyard. <font color="red"> Note that this is a special introductory price for the first 200 lights--the price will be higher after these are sold. </font>
Length: 3.32"; Maximum diameter: just under 1"; Weight 2.2 oz.
Yes, the body will be available separately.
SIGN-UP LIST for Groovy! TK Light (Nickel plated with serial number engraved and your CPF name/real name/whatever):
<font class="small">Code:</font><hr /><pre>
No. CPF Name Driver Engraved Name
1 andrewwynn ? andrewwynn Paid
2 LitFuse ? ?
3 CromagNet POP2G+ CPF Special Edition 2005 Paid
4 LaserBurnz NG750 Earthgrrrl
5 arewethereyetdadPOP2G blank Paid
6 arewethereyetdadPOP2G blank Paid
7 arewethereyetdadPOP2G arewethereyetdad Paid
8 flashlight POP2G+ CPF Special Edition 2005 Paid
9 nrk POP2G NRK
10 Dr_Joe POP2G JRL 10/200
11 StarEye POP2G+ StarEye Paid
12 Icarus POP2G Icarus Paid
13 cgpeanut POP2G+ Charlotte Grace Paid
14 leadfoot NG750 CPF Special Edition Paid
15 billybright POP2G CPF Special Edition 015/200 Paid
16 Vifam POP2G CPF Special Edition 016/200
17 DasFX POP2G DAS Paid
18 GADGETOMETRY NG750 GADGETOMETRY
19 mmdrag POP2G DRAG Paid
20 peu POP2G PEU Paid
21 dbrad POP2G db Paid
22 Toglud POP2G Torben Glud Paid
23 greenlight ? ?
24 javafool NG500 javafool Paid
25 Doc NG750 blank
26 TrueBlue POP2G TrueBlue Paid
27 NetMage POP2G+ NetMage Paid
28 sputnick NG750 ?
29 doctorf NG750 ?
30 moeman POP2G blank
31 Bogus1 NG750 ?
32 modamag POP2G+ MODAMAG Paid
33 mst3k NG750 mst3k Paid
35 Darkstar POP2G Darkstar Paid
36 shinning ? ?
37 Phylor ? ?
38 winny NG750 Andreas Vinnberg Paid
40 RchGrav POP2G+ CPF Special Edition Paid
42 RchGrav ? ?
44 mbira NG750 Groovy
45 Kilted POP2G =D~~ Kilted Paid
46 XFlash POP2G+ XFlash Paid
50 Free POP2G+ Free Paid
52 Bob_G NG500 Molly Paid
53 karlthev POP2G WB Paid
54 karlthev POP2G PB Paid
55 red_robby POP2G G
56 fleshlite POP2G+ CPF Special Edition 05 Paid
57 Marconi POP2G Marconi
62 AW POP2G+ 88888888 Paid
63 jdriller POP2G Jody Paid
65 nethiker POP2G GVC Paid
66 Colette NG750 Colette Paid
69 Sky ? WEH-2005 Paid
70 cdalyt POP2G CPF SE 070/200 Enroute
76 flex76italy POP2G+ Samuele Paid
77 rhutchinson ? ?
86 lk99bt ? ?
88 alauda NG750 88 Paid
90 mgk65 POP2G mgk65 Paid
93 jeffb POP2G+ jeffb Paid
95 Wong POP2G+ Wong Joey Paid
98 MrMom NG500 blank Paid
99 yaesumofo POP2G YAESUMOFO
100 mut POP2G CPF
101 andrewwynn ? awr Paid
111 Bogus1 ? ?
122 Bob_G NG500 Skye Dancer Paid
123 AndyB POP2G+ AJB Paid
128 Amorphous POP2G CPF Special - Amorphous Paid
133 Aluraeo NG750 ?
143 MrMom POP2G blank Paid
168 AuroraLite POP2G Semper Ad Lucem{TYAH} Paid
169 Former_Mag_User NG750 Daniel Soria
188 alauda POP2G+ Tony H Paid
189 CNTSTPDRMN POP2G Michael Robbins Paid
199 wmpwi POP2G Apollo Paid
200 Andreas ? ?
All other numbers are available.</pre><hr />
Original Thread Here: Groovy! Part I
Part II here: Groovy! -- Part II
<font color="blue">
- Single cell flashlight made from 6061 Aluminum
- Electrical driver: Your choice of a NexGen 500 mA driver, the NexGen 750 mA driver, or the POP2G driver.
- The LED will be a Luxeon III emitter, bin code TW0J
- Light output through an IMS 17mm reflector and a double-sided anti-reflection coated lens
- On/off Kroll pushbutton switch with a rubber boot
- The Groovy! will have O-rings protecting it from dust and moisture at two points of possibe entry, i.e., bezel to lens interface and at the head to body interface. The Kroll switch's rubber boot provides protection at the switch level
- The Groovy! comes with a CR123 Surefire battery
- The driver will be held in place with a retaining ring, which is easily removed with a pair of needle nose pliers
- Surface finish will be electroless nickel plate
- First 200 lights will be laser engraved with "Groovy! #123", where the 123 will be the actual serial number and whatever else the buyer wishes, i.e, his name, etc.
- Wrist lanyard
- Price: $130.00, postpaid
2 LitFuse ? ?
9 nrk POP2G NRK
23 greenlight ? ?
25 Doc NG750 blank
28 sputnick NG750 ?
29 doctorf NG750 ?
31 Bogus1 NG750 ?
36 shinning ? ?
37 Phylor ? ?
42 RchGrav ? ?
77 rhutchinson ? ?
86 lk99bt ? ?
100 mut POP2G CPF
111 Bogus1 ? ?
133 Aluraeo NG750 ?
200 Andreas ? ?
