Hi folx, I'm trying to decide between directly-driving my Q-III or sticking a Docry AAA driver into it. What are the general comparisons or suggestions between these two? (What I want to do, here, is to improve efficiency over the stock driver.)
I am interested in the general pros & cons, but my specific application is as follers: The Vf is (or will be, when it arrives from eTendue) K, and I use Battery Station's protected Li-ion rcr123a. Oh, also I should mention the two-stage tail-cap from Goldserve (I don't know the resistence yet, but it could be changed if needed.)
As I understand things so far, one advantage of the Dorcy driver would be that a 3V primary cell would work, should I ever need to use one of those...
What are the other considerations? "Well, what is your objective?" My objective is best use of the battery's energy <least loss>. The straight wire is of course the most efficient, BUT what I do not know is whether runtime would actually be compromised in a DD arrangement, because as soon as the battery's voltage drops below the LED's Vf, I'm afraid current would then cease to flow, whereas a regulation circuit would continue to run the light. Is this correct or incorrect? Or, is a straight wire actually NOT the most efficient, if it happens to turn out that the battery's internal resistance is so low that an additional current-limiting resistor is needed? (Is it going to turn out that way?)
Thanks,
-Ben
Thanks,
-Ben
