Anglepoise
I have been experimenting with the POP boards in a QIII.
The latest simplified revision , POP2G, is a winner.
First click is low then click again for high. It's as simple as that.
Low level is preset in advance to the intensity you desire. And finally, a strobe is available if required with 4 fast clicks from off.
Also it is very efficient and produces little heat when used with a TYOH.
Thanks to 'cgpeanut' and 'djpark'. I think for a light that can be picked up and used by all members of the family, this UI is the best so far. Just the fact that the POP boards can be 'flashed' to change the UI is a huge step forward.
