[ QUOTE ]
aceo07 said:
[ QUOTE ]
Haesslich said:
I don't think you should try the T2 with r123's... or any of the Inovas for that matter. Maybe you should look at the T4, which is the rechargeable version of the T3? It has the Li-Ion already built in, and we KNOW it's regulated enough to run with that.
And as far as 'good' flashlights, it depends on your needs. If you can afford one, the LionCub's a good one. /ubbthreads/images/graemlins/grin.gif Ditto the McLux-PD.
[/ QUOTE ]
Too bad I wasn't thinking when I put the r123s into the xo.. /ubbthreads/images/graemlins/icon23.gif
A good flashlight, for me, needs to be about minimag size (or smaller) with decent throw and output (similar to xo or better) and good regulated runtime (4hrs+). I want to use it for camping and hiking. Being inexpensive (sub $100) helps too.
[/ QUOTE ]
Well, if you want them all in one package... you'll be hard pressed to find it - 'good throw, bright, 4+ hour runtime, and cheap' are four ideas which don't go together too often.. or often at all. I'm not sure how well the Inovas are regulated, but the T4 sounds like your best bet to fit all those categories, outside of its size. Otherwise, the McLux or the LionCub both work on r123's and have good throw.. but blow your budget clear out of the water.
