[ QUOTE ]
Crossword said:
Has anyone else noticed that when the light is new, the rubber on the switch is slightly indented and the light sits well on a table, but after a bit of use the rubber becomes slightly domed and the light no longer sits as steadily on the tail? I have a GT & an XR and both have done this.
[/ QUOTE ]
you know, i never noticed it till i read this. the switch on mine is domed now. and i had mine for over a month now /ubbthreads/images/graemlins/thinking.gif
maybe its just me but i'm having alittle problem with my switch. sometimes when i do double clicks or triple clicks to select my brightness i cant always get it to do what i want it to do. a third of the problem is me i guess. 2/3 is like my timing is off or something. double clicking for secondary brightness my light goes off on. then sometimes for triple clicking it'll go off on off. the other is i also find that the button sticks or something so when i do a triple click it will act like a double.
for me, i prefer the button on the ARC4. i cant remember Ever having a problem with it (knock on wood), and i'm the second owner for this light. yes the button is stiff but i kinda like. when i single, double or triple click it does want i want. and you dont have to press as hard or as far in. where as the HDS there must be that click feel to it in order for it to work and it has a much deeper press.
(sorta going off topic alittle here) if i can make the best EDC light for myself, i'd have the HDS body with the ARC4 button and clip, with the reflector and the OS of the lion-heart.
