rated , BAHHH
100,000 hours of still barly putting out light is more like it.
give any of them 20,000 and they might be half bright.
i dont understand it, but phosphors are not permanent magic light outputers, they go away.
and rating any of this stuff for 100,000, in my opinion is a total lie. but then i burn them for Lamps not flashlights.
at any rate it beats the snot out of incadescent, halogen, and even florescent, and cct. but specs on how long, and how bright, should be displayed for how long AT how bright, like they are on regular bulbs we buy, that are supposedly TIME rated, at 50% output.
when SNEAKY flashlight manufactures provide spces, its just wrong, total lies.
they spec the led based on the die still operational.
they spec the output based on the first turn on.
they spec (battery) runtime, based on how long the led is still glowing enough to see over glow paints /ubbthreads/images/graemlins/smile.gif
they overdrive the LED, and dont change the "life" ratings.
and when the phosphors go, so to does the output, there is no reduced current usage when the phosphors are gone, just reduced light output. i think if parts of the gate (which will last basically forever) go, then the consumption might go down with it, depending on the curcuit used.
find me data sheets and specs that are exactally correct, or even speculated acuratly, and i will show you products that dont sell /ubbthreads/images/graemlins/smile.gif we like to be lied too.
try not to use 5mm leds for area lighting, at LEAST use high-powered leds.
Safe? there is tons of radiation comming out /ubbthreads/images/graemlins/smile.gif most of it in a visable spectrum. i think you could tie leds to a rats backside for the life of a rat, and he might just enjoy the light. but if you aimed them in the rats eyes, it would take that rat a bit of time to repair the retnal damage that might be done.
POINT lighting, has the greatest capacity to damage the eyes, because the adjuster thing (IRIS) in front of the light receptors doent adjust for single point source lighting.
so with tiny small filliments and humans staring into them like a fool staring into the sun in the desert, you could cause some damage.
just depends on how bright, and how well your iris is adjusting to it, to keep it at a level of triggering , vrses toasting.
the lack of certian frequencies of light, should make them safer overall.
