""All the true luxeons I have around do indeed have LUMILEDS on them, usually above the + contact.""
mine too, but they could have made thier own Base i guess, to save 30c ????
some (loose) specs.
its going to be hard to find stuff to FIT in this thing.
front plastic lens dia 24.6mm
Lens height 1mm
Reflector height 22.7 (reflector dropped OVER the black pastic on emitter)
Reflector Hole dia 24.1
Switch plastic body space dia 23.25
switch plastic barrel height 19.3mm
Approximate total head Cavity space height 50mm
height of heat sink plate .5mm (no misteak, its a piece of steel looking sheet metal)
Slightly ground edge 4* 26MM carlco optic would fit ohh and what a great beam. ok this is working out so good, i am modifying it in seconds as we speak.
take the top lip ring around the diamater of the carlico 4* optics off with a sander, or something, and it becomes a perfect fit.
by using the calico 4* thing, i could use IT for the lens itself, that would save 8% loss from a secondary lens , the 4* is not very tall either, Calico height 14MM . that leaves 10MM for the copper heat sink.
note 10mm WHEN the optic drops partly over the emitter black plastic.
Heat sink pill thing 10mm high, would be in a threaded area , where the threaded star top Ring holder was.
a copper disk 25mm in dia, would jam into the thread area there quite nicley. that would then conduct heat to the heads base, and carry to the slick body quite nicely.
so i am short 1 or 2 parts.
i will need the copper sink, and a 3 way switch would also be nice, but unnessisary.
HA HA, now they are going to have to move this thread again, to Modified.
