goldserve
Hello everyone!
I am pleased to announce, after a week of wrestling and debugging without an in-circuit debugger, I have completed my version of POP2 like firmware.
The firmware features 5 modes:
LOW (always starts from low)
HIGH (up to 400ma)
BURST (what ever the luxeon can pull, up to 600ma + 400ma)
STROBE (10Hz)
SOS
SET LOW MODE (18 brightness levels ranging from 5-95% of 400ma)
I am requesting a few things from you fellow CPF'ers. Any input to making the perfect flashlight would be welcomed.
I have thought of a few more enhancements. I could add detection code for long and short push button switches if and if you choose to use push button switches to advance states, you could solder two legs of the PIC together to put it into PB mode.
For now, I have mostly copied the great UI that DJ has made with the exception of low brightness setting at the end of the states rather than smack in the middle.
I am living in Toronto, Canada and would like some beta testers. Right now, I have the firmware on a Q3 POP2 board so I can send you a compatible PIC chip programmed with a customized firmware for a small charge.
For more details, PM me and we can even create a custom UI for your liking! Thanks for reading!
EDIT: I can sell a kit with two LDO chips and and a preprogrammed part for testing. You must be proficient in soldering SMALL parts! PM me for pricing and program configuration options you would like to see!
EDIT: For those who own POP2 boards and would like to see a custom interface, I can program and part and you would be required to remove the old PIC and solder the new one on.
HIGH (up to 400ma)
STROBE (10Hz)
SOS
