Re: Rerversing batteries to stop accidental \"ons\"
[ QUOTE ]
Lunal_Tic said:
In some multi celled lights that I keep for emergency I just reverse one of the cells and back off the head. + to + or - to - won't cause a problem will it?
TIA,
-LT
[/ QUOTE ]
it wouldnt in most cases, spinning the last cell around on cells that dont connect like was said above, should also be effective.
BUT
if you connected the +s or the -s and there was body connection or some other connection connecting the OTHER side up too making the batteries parellel, then that could cause a charge of any low cell, and a potential total disaster specially for something like lithiums.
basically you should know what the connection BECOMES after you make that change. if it disconnects everything, like the situations stated, then you would have a nice battery carry case
if it ONLY connects one end together, then you have half a parelell connection, and that is not a problem.
if it reverses the voltage to the curcuits, then avoid that.
also dont alway trust the batteries own insulation, if its getting abused, and the method chosen could break through the insualtion, then it could connect still.
when reversing a single cell.
it wouldnt be adequite to have 0V potential ONLY. If the switch turns on (depending on the light again), your batteries are set up for charging eachother.
hmm how would i show that.
Bulb+..switch..+BatteryA-....-BatteryB+...-Bulb
or could be shown like this
|.Bulb..switch..+BatteryA-...|
|.Bulb............+BatteryB-....|
switch goes on in this situation, in say a Incandescent light, and through the bulb the batteries are in parellel and CAN charge the low one.
charging lithium primaries might be very bad, even through a bulb or curcuit as a resistance.
li-ion or ni-mhy should just balance out thier voltage a bit.
alkalines could end up charging and leak.
basically any primary cell that did NOT like to be charged and was connected THROUGH stuff SOMEHOW could be a problem. rechargables of the same value would just have a tendancy to balance out or drain balance eachother.
if it survived any charging WHEN THE SWITCH goes on, and make a complete curcuit, then it would still be working just fine when you got to where you were going.
meaning all would seem ok, it might BE ok, but it could also cause a real bad problem.
with the insulation stopping the battery connection when reversed it would look more like this
Bulb+..switch..+BatteryA- (no connect)
(no connect) -BatteryB+...-Bulb
basically there everything is disconnected, unless your banging it around somehow damaged the insulation. the likely hood of that would be known by the user who is doing it.
