16 output levels Lux III light
waion
Hong Kong
Here's the latest brightness adjustable Lux III flashlihgt:
And here's a short demonstration video:
http://www.acad.polyu.edu.hk/~02463153d/Kiu_folder/16%20output%20levels%20light.wmv
jmy808
Hawaii
Waion,
Is there any other info that you could provide on this light? ie website, lumens, cost, etc.?
Regards,
Jay
waion
Hong Kong
I have a small amount of this little light available now.
Thank you for the link, glockboy, ernsanada.
LightObsession
How does the beam shape compare to a well known light like the Q3? Any beam comparison shots? This looks like a great light.
waion
Hong Kong
[ QUOTE ]
[/ QUOTE ]
The one you saw in the movie is an upgraded version using the TXOJ and 27 mm reflector. The beamshots of the original reflector at some consecutive levels can be seem HERE in the first post.
LightObsession
The beam picures of the original setup look like it doesn't have much spill. The video with the 27mm reflector suggest that the light does have good spill. How would you describe the beam shape and which of your setups has more spill?
Thanks.
waion
Hong Kong
Thanks for the question again. To my eyes, the well known 27 mm reflector has about the same amount of sidespill as the stock reflector. However, the central spot is much tighter and the sidespill is more even than the stock one.
