[ QUOTE ]
Former_Mag_User said:
All of the space needles are still running strong. /ubbthreads/images/graemlins/tongue.gif
Flashniac, it is best and much safer to at least use a resitor if you can get one.
[/ QUOTE ]
Ever compare them to a new same-flux binned LED driven at 1A?
Someone sent me a TNC Hyperlux V to modify for them, and it was a night and day difference in brightness compared to a Lux III driven at 800mA behind a tiny 17mm reflector, and the Luxeon V driven DD off 3x123s behind TNC's huge reflector; The Luxeon III won hands down...
Sure, it still ran, but, it didn't run well - phosphor degradation is real.
As to the question: I'd suggest using 3x123s, coupled with either a resistor in direct drive, or a DB700-DB1000 convertor from Dat2Zip's sandwich shoppe so you avoid damage to the LED. 700mA to the Luxeon V is the recommended current input.
Good luck. /ubbthreads/images/graemlins/smile.gif
