Hi all-
after lurking for quite a while I had to post this question.
Based on what I learned here, I have modded a mag D cell into a 3x3w bike light using a buckpuck, nx-05 optics and a 14.4 watt drill battery. Using my wood lathe and a rigged chuck, I took out the threads on the inside of the head where the flashlight would go, chopped off the tail and epoxied it in where the end rounded out the line of the head. I've seen pictures here somewhere of some very similar here somewhere. Other than wiring 2 of the LED's reverse and getting a nice purple hue out of them/ubbthreads/images/graemlins/mad.gif everything works well.
Anyway, version 2 has been gnawing in my brain for a while and I'm going full custom housing this time. Very similar to the EL bike lights, only with a solid back and seperate disc heat sink. Imagine an aluminum spraypaint can lid with fins and a ledge for the heat sink and you've pretty much got it right.
Since I'm going this route I haven't figured out 3 or 4 LEDs and the optics have me wondering. I like the buck puck although I confess I have nothing else to compare it to. Don't need multiple power levels, etc., just straightforward stuff.
Sooo... what are the advantages and disadvantages to the different optics? I need much more spot that flood or spill since I stick to the road, and need plenty of throw to see what's ahead. I'm kind of leaning toward a 3 spot 1 medium setup, just wondering which optics or combo of sizes would produce the desired results.
Thanks!!
Thanks!!
