NewBie
*Retired*
http://ledsmagazine.com/articles/news/2/7/20?alert=1
Cree Lighting has released a new 3-watt XLamp 7090 high-power LED in a full range of colors.
XLamp 3 in white
At the same time, Cree announced its first design win for the white 3-watt XLamp.
Cree says that the white version of the new XLamp LED is the first 3-watt product to produce a maximum luminous flux of more than 90 lumens. The XLamp 3 7090 white LED achieves an average luminous flux of 85 lumens, well above the 65 lumens typical rating reported for existing 3-watt LEDs.
At the same time, Cree announced that its new white LED will be incorporated into Cyberlux's new RelyOn portable work and emergency light.
"Based on the new 3-watt XLamp LED, Cyberlux's new RelyOn http://www.ledsmagazine.com/press/9677 portable emergency light achieves more than 60 hours of operational spot and flood lighting," said Mark Schmidt, Cyberlux president and COO. "Cyberlux is developing a broad range of products based on Cree's XLamp LEDs for emergency, task and large scale lighting applications."
The powerful, solid-state semiconductor light head, powered by three Cree 3-watt XLamp(TM) 7090 high power white LEDs, provides over 250 lumens and may be focused as an intense spotlight beam or adjusted to generate a blanket of light similar to a table lamp. The intensity of the light can be adjusted for both the spotlight and floodlight settings. A digital display shows the remaining hours of light available on a single charge.
XLamp 3 in white
