Paul_in_Maryland
The Pila GL3XR and Wolfeyes 9M use two Pila 150As to drive a 9V bulb at 7.4V, for 130 or 135 lumens. Their heads are the same heads used in their larger lights (GL4 series and M90). Those 7.8-inch-long lights will pump out 195 to 200 lumens when equipped with the 12V bulb and four CR123As...but only 130 to 135 lumens when using two Pila 168A cells and the 9V bulb.
Could someone make a threaded extender that would allow the GL3XR and 9M to use three 150As? I figure that the 11.1V (3x3.7V), fed into a 12V bulb, would deliver about 180 lumens in a light that's 8.6 inches long. In fact, the 12V bulb would be less underdriven than the 9V bulb driven by two Pilas (92& vs. 82%).
Would anyone else be interested in this extender?
