[ QUOTE ]
270winchester said:
Drive them with a single cell of 123.
THe Lux1, more often than not, have lower Vf than LuxIII's, so they are more likely to be vbery bright to the naked eye when DD's with a 123, where as most LuxIII's will have Vf of J or above, or 3.27 volts or above, so a single 123 would be a little dimm. If you have a partially drained 123 the difference will be mroe pronounced. THat's my experience so far anyway...
[/ QUOTE ]
I seriously doubt you'd be able to accurately distinguish them with that method. Remember that a Lux I Vf is binned at 350mA, whereas a Lux III Vf is binned at 700mA, so of course the Lux III Vf bin will be higher, but when run at the same current, their Vfs will be in the same range.
I have several Luxeon IIIs that, given the same current, would yield a lower Vf than other Lux I I have. Running directly off 2 AA or 1x123 cell, I can not distinguish the two with any certianty.
