DDS,
Flat sides, small clip, and smooth bezel was the first design. Next came the longer clip, then the crenellated bezel, then the round body. /ubbthreads/images/graemlins/cool.gif
I might be confused, (highly probable) but I thought the newest version of the A2 has the shorter clip.
It comes with a Z60 lanyard which uses the two-piece ring around the tailcap instead of a lanyard attachment hole in the end of the clip. Also body has multiple flat sides.
leukos; TY for the reply. I have an A2 with the scalloped bezel, long clip, long lanyard which attaches to a ring around the end cap area. The body is generally round but has several flat areas one of which the clip rests on. I presume this is the newer version.
Flash_ Gordon: sounds like what you describe except with a long clip
