goldserve
Hi All,
I am very very happy with what Doug has managed to come up with. He truely listens to all your precious input. Rest assured, the new head components will feature a metal heatsink that is made for the FLuPIC board and also, a counter sink (as seen in the following pictures) to allow the placement of any sandwhich sized converter board. It doesn't end there as there is provision to not use the new heatsink and plug in a standard sandwhich with a screw on retaining ring.
I know pictures are worth more than a thousand words so without further adieu, here are the pictures:
1: Solid metal heatsink allowing for maximum heat transfer
2: Inner counter sink for standard sized converter boards
3: FLuPIC board screwed in place so everything is very very strong
4: Another shot of the board screwed in place
5: The whole thing allows for very good thermal contact with the body and board
6: Emitter potted with thermal compound and wire from FLuPIC connected to luxeon
7: Whole assembly screwed in place with luxeon nicely centered
8: Final image of luxeon and reflector
All in all, I am very very happy as the machining that Doug has done allows me to operate the FLuPIC firmware with one hand (very smooth), allowing me access to low, high, burst easily.
Cheers!
Cheers!
