Ken_McE
- Joined
- Jun 16, 2003
- Messages
- 1,687
I'm trying to decide if liquid cooling makes sense for high power LEDs. I know lotsaluck had a project going where he would mill tiny veins into the LED heatsink and let the heat of the unit circulate cooling water. That makes sense, but it's too sophisticated for me to do myself.
I was looking at an LED glued onto its heatsink and thinking that the front half of the LED ought to be cooled too. If I housed a thin layer of fluid on top of the LED I ought to be able to get some cooling by convection.
The ideal liquid would be highly tranparent, have a high thermal capacity (thermal capacity = ability to absorb and hold heat) and a low viscosity so it would flow readily. Water is out because it could freeze. I'm thinking mineral oil or alcohol would be worth trying. There will of course be transmission losses, no way around that.
Has anyone here worked with liquid cooled LEDs? Is it worth pursuing? Comments?
