Re: How to detect a efficient crystal set in Leadl
You seem to be confused... What exactly are you looking for? An efficent laser, or an efficent crystal set?
Adjusting the potentiometer (hardly a "mod" IMO) will only show you how well THAT particular unit can be driven. The leadlight potentiometers are pretty crappy... some have intermittant connectivity, others have gaps instead of a smooth curve in adjustability, as well as not being able to get full current with others, or a combination of the three. So you may only get about 20mW out of a particular unit that might be able to sustain 40mW+, only because of a bad potentiometer.
Adjusting the pot will also show you how well a particular laser diode is aligned in the molding and barrel in conjunction with how well the MCA crystal set is aligned in conjunction with that led.
A perfect crystal will only output as well as the original LED will allow, and the LED's alignment in the barrel, as well as the crystal's alignment in the path of the IR beam also plays a significant role in how well the whole unit will visually perform or rate at.
Testing just the efficency of an MCA is completely different, and would require complete dissassembly of these lasers, a testbed to be laid out for testing, and some serious equipment that isn't cheap by any means.
In other words, you could have the most efficient GOD crystal with 100% efficency, but because of the other crappy components in a leadlight, you may not ever know just by turning up the pot.
So I guess you're just looking for the 'brightest' lasers out of the batch? You could have just said that. /ubbthreads/images/graemlins/tongue.gif
