As most CPF members know the Nuwai Q3 is a lot of bang for the buck in terms of brightness - using a 3watt Luxeon.
However the Nuwai Q3 is also known to be pretty power hungry.
Although it would be great to have it modified to be more efficient and basically "better" - it costs quite a lot to do it - and for my usage I could not really recover the cost in any battery savings.
So I decided to try the Rechargeable RCR123 for low cost power -
and being the cheap sort - I simply went to the 750mAh rated Unbranded and UNprotected RCR123 that one gets with the neat little Nano Charger from CPF member Emilion - at a total cost of $8.50 including shipping.
I am guessing that as long as I am careful not to deep discharge the RCR123 battery - it should last a few hundred charge/discharge cycles and therefore pretty easily save over the battery cost using the regular non-rechargeable CR123, even if they can be found at the bargain price of $1 each.
Another advantage I read about was that these RCR123 batteries when freshly charged get up to 4.2V and lights like the Nuwai Q3 can be noticably brighter.
I used my favorite (low priced) 1watt Luxeon S1801 from GoldenGadgets.com with a fresh Panasonic CR123 battery as a control/comparison -
Q3 on RCR123 - S1801 (1watt) on regular CR123 -
Both Q3 and S1801 (1watt) on regular CR123 -
As one can see the Q3 with RCR123 was just noticably brighter than using a regular CR123 cell.
But the surprised - or even "hoped for" result was the S1801 usng the RCR123 - was substantially brighter than on a fresh regular CR123 - to the point where I would hazard to say it was in the similar ballpark brightness as the Q3 on a regular CR123......
S1801 (1watt) on RCR123 compared to Q3 on regular CR123 -
Some measurements
RCR123 (750mAh)
initial voltage = 4.07V
end of test = 3.97V
Panasonic CR123 (non-rechargeable Li) = 2.97V
Current draw -
Q3 on RCR = 740mA
Q3 on CR = 720mA
S1801 on RCR = 740mA
S1801 on CR = 470mA
Comments - possible Caution - the 1watt S1801 got pretty warm using the rechargeable RCR123 drawing 740mA - which is the same as the measurement for the 3watt Q3.
I am not sure if 740mA is a safe current to drive a 1watt Luxeon -
perhaps some of the more experience Luxeon users can please advise?
Some measurements
RCR123 (750mAh)
end of test = 3.97V
Current draw -
Q3 on RCR = 740mA
Q3 on CR = 720mA
S1801 on CR = 470mA
