Since proton is not going be available, I am thinking about getting a HDS, either B60 or U60. I have a few questions hope HDS owners can answer..
1. Do B60/U60 truly produce 60 lumens? I read some posts stating they are dimmer compare to SF P6, which is rated at 60 lumens.
2. Does the basic model have momentary on capability? My understanding is it doesn't.
3. Does the switch actually "click"? By reading the instructions, it seems it's implied that the switch doesn't actually click, that's why the manual has to define what's a "click".
4. After reading the manual my understanding is the basic model can't be turned on momentary. Is this true?
5. The instruction defines a "press", necessary for momentary on, as a push longer than half second. Does this mean there is a 0.5 second delay for momentary on?
Thanks in advance!
Thanks in advance!
