Brock
Ok, I have these two 5000 btu water to air heat pumps. They were originally intended to be used to heat a hot water tank and blew out cold air each has it's own small pump and they are hooked up in series.
I run water from our pool to them and then duct the air out of them to the furnace returns, running about 18 hours a day would keep the pool at temp and greatly offsets the AC running time. I only run them off peak (when electricity is ½ price).
My first question is I have calculated it dumps the water back at a 10 degree F rise (85F to 95F) at 2 gallons per minute. I know you can somehow convert that to BTU's but don't remember how.
Secondly. Right now the intake and return lines are 1/2 inch and about 40 feet total. I was told making the pipes larger, say 5/8 or even 3/4 wouldn't make any more heat, just a faster water flow and lower overall temp and the air output temp would also be the same. Is this true or would larger lines help?
