Josey
My Surefire 10X charger isn't charging, and there seems to be a loose connection somewhere.
When I put the battery in the cradle, the charging light shows only dimly. And the battery does not charge.
But if I shake or bump the charger, sometimes the charging bulb comes on full brightness, but only for a flash or a few seconds.
I don't see anything loose or any bad solder points.
When I take the charger apart, I see 15V hitting the incoming ports from the wall wart.
Seems like this should be an easy fix, but I don't know where to go next.
I'd appreciate any help or ideas.
Thanks.
Josey
Thanks.
Josey
