Phaserburn
Ok, here's my plan. I want to build a red/orange lux III screamer and get at those rated 190 lumens of eye-frying power. Now, here's what I think I think - I need good heatsinking to accomodate the 1.4A current required for this output. My host of choice is the Emilion Smartfire 3AAA direct drive clone light. Swapping the clone for the R/O lux III, I think the heatsinking would be adequate. For power, I'd be using 3 AAA nimh cells, which should, in theory, be able to supply this kind of current which should be a bit under 2C. I could use a li-ion 18500 cell as a swap out for the 3AAAs. So the questions are:
Which battery source would be better? I realize that the 18500 would provide much more capacity than the 3AAAs (1500ma vs 900-1000ma), but would I be overdriving the luxeon to dangerous levels? The R/O bin is G2HH. What voltage is required to push the correct current through this baby? I know that the H vf is 3.03-3.27V, but that's at 750ma, isn't it? I think the li-ion would hold a higher voltage than the 3AAAs for longer, but it would be relatively close, I believe. And the li-ion would have no problem supplying whatever current the luxeon would be willing to draw.
Opinions?
Opinions?
