[ QUOTE ]
Thermalarc said:
It's known that the U2 will fall out of level 6 using a Plia 168a after some time. Is there a way around this? Will using an unprotected li-ion cell with a higher voltage solve the problem? Will the U2's regulator replace the over-discharge issue when doing so? If so does such a battery exist and can anyone point me to a source? Gracias.
G
[/ QUOTE ]
I'm really not sure what you are referring to, I do not have Pila 168A's. On my U2 when level six goes away it is time to recharge the cell. I get about 90 mins on bare 18650's, when level six goes away I know I have about 15-30 minutes left to lights out.
I got my 18650's from IBM Thinkpad battery packs from laptops being idle & excessed. I got about 20 of them seems like they range from 2000-2200mah. I have a Maha C777plus-II charger.
I popped the tail cap and put an amp meter from the cell to tube and measured 1170ma.
=D~~ Kilted
