Ok you got it off! That will make things a lot easier!! Clean it up good, scrape any excess epoxy off of it, as well as the o-sink.
Ok, when you go to re-do this, mix up enough AA to cover the o-sink surface, up to the edges of the self-aligning ridges. Then slather some on the slug of the luxeon, Press and rotate till it locks in, press down in the center once more. Then wait a little for it to start to harden, and test the resistance of the postive slug and the HS. If you're good, well, good!
That's how I did mine and it worked fine.. If it still doesn't work, then you'll need to put a THIN layer over the slug or HS first, then put it togther, Just make sure it's not too thick to keep the Luxeon from touching the HS fully..
If this is a LuxIII red then you defienalty need the full contact of the HS!
