Integration Sphere Information
I had a long talk with Chris at
www.sphereoptics.com about our "hobby" needs for an integration sphere. He is going to send me a manual to check out and is willing to help us set a system up.
The first question was about how large the lights we are wanting to measure are. I told him the range ran from ¼ inch to 8 or 10 inches. He said that for an 8 or 10 inch aperture, we would need about a 40 inch diameter sphere. Of course the cost goes up with an increase in diameter and the logistics of a "pass around" of a large sphere can be a bit difficult as well.
He suggested that the 12 inch unit would be a good compromise for our use. It has a 4 inch aperture, which would cover a lot of the lights we use, but you could not test a Thor in it.
There are some maintenance issues as well as some set up issues, but they don't seem to be that difficult to do. Fixtures need to be made to hold the lights in place, and the unit needs to be calibrated prior to each use.
The standards call for 3 independent calibration source checks. This is done with a NIST traceable set of 3 lamps that are checked prior to the test run. They sell a "3 pack" of these calibration lamps for $2000.00, or you can purchase them individually for $900.00 each. The lamps have a "calibrated" life of 50 hours, then need to be replaced.
This is not as bad as it sounds. Once you have the system set up, you can pick up some automobile tail lamps and do a cross calibration. Some people have used their calibrated lamps less than 50 hours in over 10 years… The calibration lamps need to be free from fingerprints and need to be protected against corrosion and breakage. Also, a log needs to be kept to track lamp use.
The suggested unit is the SLM12. It consists of a 12 inch sphere, a calibrated lab quality power supply, a spectrum analyzer that runs in the 300-1050 nm range, and the Windows based software to run the unit and gather data. This will give us Luminous Flux (lumens) of a lamp (or flashlight) operating at a user specified current or voltage. It can also accommodate a battery operated light as well. In addition, the spectral data on the light is collected, including the chromaticity values of x, y, z, u, and v, correlated color temperature, peak wavelength, and dominate wavelength. This data can be exported to Excel (or your favorite graphing program) for further analysis.
The cost of the SLM12 is $13000.00.
He is willing to consider a small discount (maybe 5%) in exchange for a banner ad, or other form of advertising.
This unit is somewhat portable. The sphere, power supply, and spectrometer can be packaged up and shipped without too much difficulty. To run the unit all that is needed is a Windows based computer with a USB connection. There will be some minor additional costs to come up with fixtures to hold the lights and lamps, but I think we have some clever and creative people here with access to fabrication equipment that may be convinced to help.
Let's see now… $15000 divided amongst 500 people works out to about $30 per person…
Chris did also mention that they offer testing. The set up cost is $450 and then it is around $30-$50 per test. He suggested that we may be able to earn some of our cost back by offering testing at a "competitive" price.
Tom
