spoonrobot
- Joined
- Aug 2, 2005
- Messages
- 396
Will the Streamlight Propolymer Luxeon function with lithium AA batteries or will it fry the LED?
spoonrobot said:Will the Streamlight Propolymer Luxeon function with lithium AA batteries or will it fry the LED?
Lunal_Tic said:TIN,
Are you using E2s or Battery Station's? The latter have really high voltages. Mine have been up around 1.9V
-LT
Phaserburn said:Cold weather performance aside, lithiums kind of defeat the excellent regulation setup of this light. It runs FLAT for around 3.5 hours on alks. Even nimh cells would be questionable unless lots and lots of use is expected. Remembering that alks are only around 25% of the price of lithiums (at the very best), you get 14 hours of regulated performance vs probably not a whole lot more with lithiums. Even a 20% increase wouldn't make it worthwhile. The alks just aren't being hit hard enough to justify the expense by rewarding you with extra performance.
If you don't get a brighter, more constant output or longer running light, why use lithiums? BTW, I do use lithiums in many of my lights, but in this case, alks are what seems to be best for this design. Just my humble opinion, such as it is.
IsaacHayes said:Is the PP luxeon regulated or just resistored? I take it the first...?
