cgpeanut
OK, I wanted to create a new sammie using the latestet POP2E v2.39 so I said why not the Orb Raw? Just finished it last night so it's not ready to primetime yet.
Left: POP2E v2.39 Right: Original Orb Raw pcb.
Left: POP2E v2.39 PCB Right: Orb Raw DD pcb
I matched the thickness of the Original Orb Raw pcb which was .106"
EDIT:
I'm using TPS73201 as primary and TPS73101 as secondary with TWOH luxeon, Output is in the range of 250-300 mA at full brightness. I want to be able to run at least 4 hours at low mode.
EDIT:
