Marc,
Thanks for your comments and observations. I think the illusion created between the contrast in light levels (spot VS corona) will lend the perception of throw to the high contrast beam where in reality the actual level of target illumination may not be what it seems. As flashaholics, even outside in use, we often look at the beam and not that which the beam is illuminating. We seek and use contrast in light on the target for information but artificial contrast created by the beam can be in conflict with *real* information and/ or perception. I agree that the HD45 is no beauty contestant! :green: That was never the intent and some of its lines are in place for ruber armoring that never came to be. :shrug: It would have been even uglier had the suit of armor actually come about! Your comment about the light output not seeming to follow from the specified current drive levels I think really points to the change in efficacy relative to drive levels and the real value in underdriving these LED's!!
Bill,
I think for many, the Aleph 3 is already too big and too "top heavy" for the E series lights. The HD45 came about as I wanted a larger light based on a 1" OD battery tube with heavier wall thicknesses for a more
Heavy
Duty light with greater thermal and physical abuse capacity as opposed to the Aleph or E series lights. Since size was not so much a constraint, I figured I could add depth and diameter to the 38 mm reflector and came up with the 45 mm reflector.
The 45 mm in an Aleph head would be really out of porportion and I don't think the demand would come close to consumption of the parts I would have to invest in and stick on the shelf. Heck, it looks like I will be passing on some Aleph 3 parts to my heirs!
I went for a minimum size run on the HD45 parts as I feel this light is legitimate but certainly "specialized" for application and very likely limited in demand.
THe HD45 is a basic and boreing light but it is a canvas that can be set upon by the user and tweaked more to their needs. With a hand drill and tap, attachment points can be made and modified. An
example is shown below on one I keep in my van for "whatever".
Admittedly, I am fond of the web coil tethers! :nana: The Ti belt clip enhances the rotation of the head for switching to light levels as well as on and off.
