NEXTORCH - 300 m long-shot E6
Page 13 of 13 FirstFirst ... 3678910111213
Results 361 to 380 of 380
Thread: 1kW Xenon Arc Tank Light
  1. #361
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Default Re: 1kW Xenon Arc Tank Light
    OK. I may buy two just because. They may be a few dollars more if we don't take them all.
    WWII 60" Carbon Arc (Sold), 1.6KW NightSun, 1KW VSS-3A, .8KW TrakkaBeam, 600W M-134 Light, 500W X-500-14s, 500W Starburst, 500W A120b, 450 Watt AEG German Leopard 1 Tank Light, 300W Locators, Megaray, 150W Communicator, Maxabeam Gen3, Pichel 75W Mini-Novas
  2. #362
    Unenlightened
    Aug 2007
    Texas
    Picked up my Vss-3 today. It came with the light, mounting plate, cable for light to control box and the control box. Need to have a cable moade for the power source. Is there anybody here that can help me with the power cable? Looking for one to hook into the slave receptacle on my HMMWV and use the vehicle as my power source.
    Surefire: Hellfighter,XC1,M6,Z3,Scout,X200,E2,6P's,C2 Fenix: P3DQ5; Zebralight: H50Q5; Blackhawk: Gladius Klarus: XT11 Maratac: AAA,C,D Jetbeam: RRT01,BA10 Blackshadow: Queen,Terminator Convoy: S2,L6 First Light: Tomahawk Other: VSS-3, GoLights, Ibis Tek Light Bars mounted on HMMWV
  3. #363
    Flashaholic* FRITZHID's Avatar
    Jun 2011
    Icelandic wastelands of Monico, WI
    Pretty sure most people build their own. I built one for member BVH a few years back and just finished building one for mine yesterday.
    IDK where one would find a stock connector/cable. BVH sent me the connector for mine, not sure where he got them.
    I Got tired of looking for the light at the end of the tunnel so i lit that bitch up myself! Convoy s2 365nm, Maxa-Beam Gen II, 55w hid/100w incan Vector Twin, Amondotech n30, vss-3A, Reylight Ti Lan v3, Helius Sigma 9, astrolux s41 219, Shadow JM35, BLF GT,
  4. #364
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Quote Originally Posted by jake-cutter View Post
    Is that the smaller "remote control" box or the full-size control box. It's hard to tell at the angle? It looks quite different from the VSS-3A box (there is a difference)
    I was just ready to place an order to a source in Israel for 4 extra newer style lamps for these lights. Do you want one or more? They are $140.00 shipped to me and then whatever shipping is from me to you. Or if you want to deal with him, I can provide the contact info.
    I buy most my connectors from a source here in Calif that is usually cheaper than going with the usual big electronics suppliers. Let me know if you want the contact info.
  5. #365
    Unenlightened
    Aug 2007
    Texas
    Its the full size control box I think see below. For now, I will pass on the spare lamp, but would like to know your source for the connectors. I believe for the power cable I need an MS3108B32-5S as shown in the link below and the connector for the wire to feed through. I have a slave plug already, but would need someone to make the cable for me as my solder skills are lacking.
    http://www.galco.com/buy/Fujikura-Fo.../DMS3108B32-5S
    http://www.galco.com/buy/Fujikura-Fo...DK/DMS3057-20A
  6. #366
    Jun 2011
    That picture link is blocked for us by Photobucket, fyi.
    as far as a cable goes, i can build you one.
  7. #367
    Unenlightened
    Aug 2007
    Texas
    I will switch the pictures to imgur or another hosting company later this week. As for making the cable FRITZHID, I will probably take up on that. What do you think about using the Amphenol type connectors I listed, about 5 or 6 ft of wire and then a quick disconnect of some sort (similar to welding quick disconnects or flat quick disconnects like the ones in the link below). That way I can add or subtract length and only worry about making a cable with the quick disconnect end and not messing with the Amphenol connector. That way I could mount it on the vehicle and use a short end quick connect cable or in a trailer and use a long cable with the same quick connect end. Just not sure what size wire and the amp is on these lights to know which quick connector is better.
    https://www.amazon.ca/dp/B014FEV6EU?tag=vglnk-ca-c52-20
  8. #368
    BVH's Avatar
    Sep 2004
    CentCalCoast
    The Amphenol connector numbers are in this old post: http://www.candlepowerforums.com/vb/...=1#post1871898 The connector and strain relief you link are very close, if not cheaper than my source - Connector Distribution Corp. I'd buy em before they raise the price.
    I did exactly what you are talking about doing - using the quarter-turn welding quick connectors on the other end of my input cables. They work great. I would not use the 50 Amp connectors you link to. The light runs on about 58 Amps once settled and up to 100 Amps at startup. If you want something like that, go to Powerwerx.com and look at the Anderson variety. They look almost the same. Buy the 175 Amp size - https://powerwerx.com/anderson-sb-co...s-sb175-175amp
  9. #369
    Unenlightened
    Aug 2007
    Texas
    BHV, do you have a link to the welding quick connectors you used? I ordered the Amphenol connectors from Galco so that's at least done.
  10. #370
    BVH's Avatar
    Sep 2004
    CentCalCoast
  11. #371
    Mar 2006
    Calif.
    Wow another VSS-3 owner with a HMMWV mounting platform. Small world.
    Have fun with it.
    NL
  12. #372
    Unenlightened
    Aug 2007
    Texas
    Quote Originally Posted by NITE LITE View Post
    Have fun with it.
    NL
    Yours was one of the two HMMWV's that I found with VSS-3 mounted and I knew I had to have one. Need to fab a mount similar to yours or like the one on the g503 forums that mounts on the regular pintle.
    On a side note, does anyone know if the mounting holes on the bottom are in the exact same location on the VSS-3 and the VSS-3A? I would think so, but want to confirm.
  13. #373
    Mar 2006
    Calif.
    I would guess so however I only have one so I can't compare . I believe they both fit the same base plate on the tank .
    I think they were the same physical se just one had clipped corners.
    I can look through my manual and see if it has some actual technical measurements.
  14. #374
    Enlightened nealitc's Avatar
    May 2005
    San Francisco CA
    Quote Originally Posted by BVH View Post
    (Yeah, a bit delayed reply.)
    Fujikura (Formerly DDK) clones from Galco are significantly less expensive than Amphenol.
    jake-cutter has links in this post http://www.candlepowerforums.com/vb/...=1#post5162424
  15. #375
    Moderator
    Dec 2008
    Penn's Woods
    So who here is selling the tank light on the 'bay???
    Wildflower seeds on the sand and stone
    May the four winds blow you safely home...
  16. #376
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Have a link?
  17. #377
    Moderator
    Dec 2008
    Penn's Woods
  18. #378
    BVH's Avatar
    Sep 2004
    CentCalCoast
    That one has been on and off Ebay for a couple of years. I don't know if it belongs to anyone here or not. Price is high. Nice power supply that goes with it but a bit under powered. The light wants about 100 Amps momentarily when starting and his ad makes it sound like the PS is not really up to the job, having to multiple-strike it sometimes. Steady running is more like 54-60 Amps depending on the fine tuning of the Voltage so it's right at the max of the PS. He's running it at about 27 Volts in the pic. If cranked up to the full 28.8, it would probably be drawing 58 Amps.
  19. #379
    Moderator
    Dec 2008
    Penn's Woods
    Thanks for the info!
  20. #380
    Flashaholic Phased_Array's Avatar
    Mar 2005
    Hinsdale, IL, United States of America
    I don't know how many of us have the -3's. I have a source for 11 lamps. I've purchased from them before with good results. Any takers? If all 11 are purchased, we can get them for $125 each shipped to my door and then a few dollars more for me to ship to individuals.
    I still have my AN/VSS-3. A complete setup with a 'military power supply' for 110VAC use. I welded up a AN/VSS-3 mount kit for my roof mounted 50cal pintle mount on my HMMWV, plugs right in to the HMMWV power.
