Well,
There's a diode in the charger ring but this should not affect things. As long as you don't try to punch it with a 1 amp or higher rate, should not be a problem. Do you remove the pack from the light to charge on the RC charger? Which ring are you using as the positive?
What do you mean by "accu"?
Wilkey
