LightObsession
- Joined
- Nov 12, 2004
- Messages
- 1,385
Should I attempt to send it in for repair, or perform some kind of mod to it? I don't have a working M@G to compare it to for troubleshooting and this is the first M@G I've handled. I don't have any paperwork for it or a receipt, so would M@G even accept it for a warranty repair?
It was donated to my church for a garage sale and it doesn't work. Both bulbs light when connected directly to the batteries outside of the flashlight - even with the tail cap in series on the end, so the tail cap is ok too.
I measure 3.2v at the empty lamp socket with my DMM until I put the lamp in series with the DMM, then the voltage drops to 0v. This leads me to suspect a problem with the switch, or something between the + contact of the battery tube and the + spring of the lamp socket that won't allow it to carry any current at all, but allows voltage without a load. I was going to remove the switch assembly to troubleshoot it, but I didn't have an appropriate tool to remove the retaining ring.
What would you folks suggest for my next step?
